Dimmer switch remote switch options?
I have seen a bunch of info on these upcoming dimmer switches and am having a hard time figuring out what is supported from a 3 way or even 4 way standpoint in regards to the remote switches. It seems like there are a bunch of caveats based on the type of remote switch you use, aux vs dumb vs smart, and neutral vs no neutral. Is there any documentation/matrix that detail the features on the remote switch you gain or lose based of each of these or what is even an option from a technical standpoint?
For my use case specifically I was wondering if you could install smart dimmers for both switches and be able to dim and display status on both smart switches? This would all be with a common wire if that makes a difference.
