Config:
LZW31-SN Red Dimmer
Neutral
Load Only
Load is ~30W fluorescent, pretty old ballast (admittedly) but I have the switch working with a higher load (180W) set of 3 fluorescents.
Switch installed just fine and works with hub, commands, etc. When switched on (at 100%) it is only showing ~6W, is about 20% level (makes sense), and the bulbs are flickering/pulsing.
Since I have neutral at this switch location I assumed all would be fine. Do these not work well with older ballast/fluorescent assemblies?
I removed the switch and went back to my normal switches and everything works normally.
Thanks for any help,
Kevin
