So I have setup z-wave associations between each switch and the 5 bulbs but only one switch seems to work properly. Both switches have their own association for group 2 and group 4 so a total of 4 associations. Is it a limit of the z-wave association tool that I can’t put the bulbs in more than one group 2 or 4 association?
If so, what is another way that I can have these turn on or off as quickly as the z-wave association works?
They are all S0. Is there a limitation with the z wave association tool that could be limiting me? If not I may try to exclude then include the switch that doesn’t seem to want to work properly.
I spliced the power to be on all the time at the sockets. I haven’t set the dimmers to smart bulb mode or disabled the internal relay because I shouldn’t need to with how I have it wired.
