I have an Inovelli Blue 2-1 Dimmer with a dumb 3 way switch. In normal (non Smart Bulb) mode, the switch works as intended.
In Smart Bulb Mode I bound the switch with the bulbs. The switch can only control the bulbs when the 3 way switch is in the “on” position. I know the binding works, because when the 3 way switch is on, the Inovelli correctly controls the bulbs.
I know the 3-way wiring at least works because in non-Smart Bulb mode, both switches work as expected.
Is this a firmware issue or is this not a compatible configuration?
