Question about led with red series dimmer
Hi everyone,
In the next few days I’ll be installing 6 red series dimmers and was wondering if anyone has tried the Parmida retrofit leds? I contacted to manufacturer and they told me that the led uses (Driver on board) DOB led Technology and leading edge compatible. I will post a link to the lights I have throughout my home. 5/6" Disk Light | Flush Mount Ceiling Recessed Lighting | Parmida LED — Parmida LED Technologies
Your opinions would be much appreciated. Thanks
Eric said here that the dimmer switch uses leading edge dimming. Since your lights are leading edge compatible you should have no problems!
Thank you for your response. I actually ended up trying the switch to see how well it worked with my leds and it worked perfectly. installed 7 on them last weekend.
