v1.36
Associations: Group 1 only, endpoint 1
The device is only being used as a scene controller with no loads. So in this case I am pressing and releasing the bottom button and toggling another switch via the event notification that is generate.
From the HomeSeer4 log it appears that on a single button press a MultiChannel V3 packet is received, which HS4 translates to a Central Scene V2, which then trips by “Button was pressed” event. Then a Central Scene V2 packet is also received from the device, which of course trips the same event again. It happens that the second event comes in fast enough that the state of the switch being toggled has not yet changed, so both events tell the switch to do the same thing. But obviously such fortune cannot always be relied on. Can this be remedied with some alternate association?
Log:
ApplicationCommandHandler from Network: F255241A Node: 154 HANDLING: COMMAND_CLASS_MULTI_CHANNEL_V3 Frame(7)=13
Payload1: 5B-03-3F-80-01-B1-00-42
Frame: 60-0D-00-01-5B-03-3F-80-01-B1-00-42
Payload1 zd is not nothing
Set_New_Level_Real: Initial device is Main Floor Library Central Scene
Set_New_Level_Real called for Main Floor Library Central Scene, Type=COMMAND_CLASS_CENTRAL_SCENE_V2, EndPoint=0
Set_New_Level, Parent: Main Floor Library Scene.Root, Child:Main Floor Library Central Scene
Setting device Central Scene to value 1000 Network: F255241A Node: 154 Device Ref: 1890
Event Trigger “Main Floor Library.Cabinets - Toggle”
Device: Main Floor Library Cabinets to Off (0) by/from: CAPI Control Handler
